TwinTurbo.NET: Nissan 300ZX forum - Does the noise change when clutch pedal is pressed in?
ZXoltan
on April 02, 2023 at 11:43 AM
98 spec 5-speed is crap.
posted by Good2Zya2.0
on April 02, 2023 at 12:10 AM
Noise with the pedal pressed down is typically a throw-out bearing. It sounds like you def have an issue with a trans bearing, but may have an additional TOB problem.
Good2Zya2.0
00:10:13 04/02/23
Cracking the case open the input bearing is right up front.
SkiFly01
02:23:56 04/02/23
'98 trans whine
JMartz
12:30:19 04/02/23
Fortunately I still have my original transmission....
Good2Zya2.0
14:28:46 04/02/23
I think you should try a fill of MT-85 before swapping back
Polishzx
14:53:55 04/02/23
Well the 85 won't fix my already F'd up bearing...
Good2Zya2.0
23:42:35 04/02/23
Post a video (n/m)
Drk93TT
10:41:28 04/03/23
I don't believe that it's the bearing (n/m)
11:38:43 04/04/23
Mistake was changing the fluid and putting in
MixManMash
08:05:49 04/02/23
Re: Mistake was changing the fluid and putting in
Good2Zya2.0
13:49:29 04/02/23
That information is incorrect. Lots of evidence of people
MixManMash
20:15:57 04/02/23
Well they claim the only one they had a problem with...
Good2Zya2.0
23:31:15 04/02/23
I had 2 of those transmissions
Drk93TT
08:43:23 04/02/23
So what did you do with them? Also...
Good2Zya2.0
14:10:40 04/02/23
I bet the Redline MT-90 is the problem, it should be MT-85
Polishzx
11:31:15 04/02/23
I switched to MT 85 last year, shifts seem smoother (n/m)
itsa300zx
13:31:56 04/02/23
That was my experience as well
Polishzx
16:31:32 04/04/23
Does the noise change when clutch pedal is pressed in? -
ZXoltan
11:43:11 04/02/23
Re: Does the noise change when clutch pedal is pressed in?
Good2Zya2.0
14:02:12 04/02/23
Re: Re: Does the noise change when clutch pedal is pressed in?
ZXoltan
21:25:13 04/02/23
According to the article my pilot bearing is shot....
Good2Zya2.0
08:06:15 04/03/23
Just to be clear, the noise does not change when you
black300zx
12:13:29 04/03/23
It only whines when the clutch is released/out....
Good2Zya2.0
16:43:40 04/04/23
Got it, thanks for the clarification
black300zx
07:34:35 04/05/23
CORRECTION:It only whines with the clutch RELEASED/OUT (n/m)
Good2Zya2.0
17:00:34 04/04/23
Thats a pretty big correction to this thread. lol (n/m)
Drk93TT
17:09:12 04/05/23
Just a tiny detail :-P (n/m)
ZXoltan
12:47:26 04/06/23
I guess I should have read what you said more carefully
Drk93TT
05:44:49 04/03/23
Re: I guess I should have read what you said more carefully
Good2Zya2.0
08:37:09 04/03/23
Could be input shaft bearing like you said.
Drk93TT
10:44:24 04/03/23
LOL (n/m)
Adam (NoVA)
10:54:52 04/04/23
Listen to me now, believe me later..
11:42:03 04/04/23
Indeed (n/m)
Drk93TT
15:29:16 04/04/23
Oh come now - what about the special "anti-rust fluid"
Adam (NoVA)
10:32:11 04/05/23
Nice LOL
ConVerTT
20:13:43 04/08/23
*shrug* mine's great
vorpalZed
22:46:14 04/12/23
